Tema: Alpine MRV-F505
    Pagal nutylėjimą Alpine MRV-F505
    Parduodamas labai neblogas Alpine stiprintuvas, turi savitą tikslumą ir aštrumą. Yra naudojamas su Rainbow CSX ir SLC serijų komponentais, taigi bus galimybė ir paklausyti, kol pajungta. Turi galios užmaitinti ir du negalingus žemadaznius. Turi pilną filtravima, ir visokio kitokio gerio. Turiu du keturkanalius tad šitas tampa nebenaudojamas.
    350lt
    http://i85.servimg.com/u/f85/14/55/86/11/_mg_2617.jpg
    4/3/2 Channel Operation
    MOSFET Power Supply
    DC-DC PWM Power Supply
    No Current Limiting
    Double Buffered Pre-Amp Input Circuitry
    Discrete Pre-Amp Stage
    MOSFET Final Outputs
    DC Straight Design
    STAR Circuitry
    Duo Feedback Circuit
    Solid Copper Bus Bars
    Top Mounted LED Power Indicator
    MultiMode
    Independently Adjustable Crossover (HP/
    LP/BP Capability)
    Top Panel Adjustment of Crossover and
    Gain
    4 Volt Straight Input Switch
    Input Mode Selector Switch
    Continuously Adjustable Gain Control
    Gold Plated RCA Input Connectors
    Extra Large Gold Plated Screw-Down
    Power Terminals
    Gold Plated Screw-Down Speaker
    Terminals
    Non-Fading Pre-Amp Output
    RMS Power (at 12V, 20Hz20kHz)
    Per channel into 4 ohms .................................................. ........... 50W x 4 (0.08% THD)
    Per channel into 2 ohms .................................................. ............. 65W x 4 (0.3% THD)
    Bridged 4 ohms .................................................. ..................... 130W x 2 (0.3% THD)
    RMS Power (at 14.4V, 20Hz20kHz)
    Per channel into 4 ohms .................................................. ........... 75W x 4 (0.08% THD)
    Per channel into 2 ohms .................................................. ........... 100W x 4 (0.3% THD)
    Bridged 4 ohms .................................................. ..................... 200W x 2 (0.3% THD)
    General
    Frequency Response .................................................. .............. 10Hz50kHz(+0, -1dB)
    Signal to Noise (S/N) ............................................ 105 dBA (referenced to rated power)
    Input Sensitivity (for rated power) .................................................. ............. 200mV to 4V
    Sep 2011
    kainos nematau?
    Atsiprašau, pataisyta. 350lt
    Pakylam, galimos akcijos Arba mainai
    Citata Inproof rašė čia: Peržiūrėti žinutes
    kas domina mainytis?
    Pagrinde i kita keturkanali, bet gal sudomintu ir kitkas, kazkas is akustikos
    kokie reikalavimai keturkanalui? nes turiu JL 300/4........
    http://www.autogidas.lt/jl-audio-sla...-15535528.html
    hmm keliaujam i pm
    Trys šimtai litų
    neskaitau taisyklių
    Iškeliavo tampyt kažkokio axton žemadažnio
