Tema: Jl audio e4300
    Pagal nutylėjimą Jl audio e4300
    Parduodu puikios būkles JL audio e4300
    http://photos.autogidas.lt/s/photos/...udio-e4300.jpg
    Class AB 4-Channel Amplifier
    Absolute Symmetry Class AB Circuit
    Differential, Noise Cancelling Input Topology: RCA jack inputs(low-level) and multi-pin jack(high-level)
    On-board crossover: State-variable, 12dB/octave Butterworth with continuously variable cutoff frequency selection from 50-200 Hz. Configurable as Low-Pass or High-Pass
    Preamp Output: Pass-through type
    CEA-2006 Compliant
    RMS Power Rating (14.4V):
    4 Ω: 70 watts x 4 chan.
    2 Ω: 110 watts x 4 chan.
    Bridged (4 Ω): 220 watts x 2 chan.
    Bridged (8 Ω): 140 watts x 2 chan.
    RMS Power Rating (12.5V):
    4 Ω: 45 watts x 4 chan.
    2 Ω: 75 watts x 4 chan.
    Bridged (4 Ω): 150 watts x 2 chan.
    Bridged (8 Ω): 90 watts x 2 chan.
    Frequency Response: 10 - 25kHz
    Damping Factor: >200 @ 4 Ω / 50Hz, >100 at 2 Ω/50Hz
    S/N Ratio: >104 dB referred to rated power(A-weighted, 20Hz-20kHz noise bandwidth)
    Input Range: 200mV - 8V RMS
    Bass EQ: +6dB Fixed Frequency, Fixed 'Q' with port for optional remote bass control
    Slew Rate: +- 22V/us
    Dimensions: 13.8" L x 9.25" W x 2.36" H
    1-year SonicElectronix.com warrant
    Buvo pajungtas su 2x jl audio 12w0 Idedu "kratymosi" video..
    http://www.youtube.com/watch?v=1QvrHvIyfCA p.s. video mano.
    Su neaiškia dėže (uždara 2x35l) buvo ipūsta 138db 47hz
    Dabar pajungti komponentai prieki.
    Geras stiprintuvas ir zemadažniam ir komponentam.
    Domintų keitimas į kažką su 600-700++ rms prie 2ohm
    Kaina 420lt
    389 ir Dalyviams akcijos nuolaidos ! Tiems kas supranta!
    379lt Keitimai nebedomina.
    Niekam neidomus ? 369lt
    Akcija Tiek kas supranta!
    o ką reikia suprast - niekaip nesuprantu ...
    Trys šimtai penkiasdešimt vienas litas.
    Parduota
