Tema: Rockford Fosgate 500S. Kokį subą jungti?
    Jaunius Dangus is on a distinguished road
    Sep 2010
    Pagal nutylėjimą Rockford Fosgate 500S. Kokį subą jungti?
    Sveiki, turiu tokį stiprintuvą RF 500S:
    • stereo, bridged mono or Tri-Way output
    • 125 watts RMS x 2 at 4 ohms
    • 250 watts RMS x 2 at 2 ohms
    • 500 watts RMS x 1 at 4 ohms in bridged mode
    • variable 50-210 Hz high-pass/low-pass crossover, 12 dB/ octave
    • TOPAZ noise-killing differential inputs eliminate 80% of ground loop noise between the head unit and the amp
    • NOMAD advanced protection circuitry monitors temperature, voltage, current and impedance, and provides "intelligent" shut-down protection without limiting system performance
    • TRANS•ana circuit designs keep voltages low and signal paths simple in the pre-amp section, for minimum distortion and maximum musicality
    • MEHSA provides more efficient transfer of heat from MOSFET output devices to the heatsink for cooler operation
    • speaker- and preamp-level inputs
    • Punch Bass boosts bass up to 18 dB at 45 Hz (wired remote control included for fingertip control)
    • dimensions: 13-3/8"W (9-15/16" without endcaps) x 2-7/16"H x 9-7/8"D
    • 1-year SonicElectronix.com warranty
    Kaip suprantu "subridžinus" gaunam 500rms prie 4 omų. Ar tai realu? Ir kokį subą patartumėt jungti? Gal turit ką pasiūlyt? Gal parduodat?
    Prie geros elektros šitas stiprintuvas atiduoda gerokai daugiau nei 500rms
    Kiek skirta subui?
    Sep 2010
    Kaina nėra labai svarbi, svarbu, kad būtų kokybės ir srauto
    Rašytojas Blogulis is an unknown quantity at this point
    2in1 gali būti kava,o ne srautas su kokybe vienam apiforminime.
    Kas tas srautas? Kitu syk forumuose besilankantis pilietis paskaito, bet nelabai susigaudo kas tas yr, bele pasakymas patinka...
